В дискуссии GisList была такая тема:
Вопрос:
I've ping'd this list for the answer before, but I neglected to save the
solution. I've installed an evaluation version of 3D Analyst for
ArcView8.x. It has now expired, and even though I uninstalled the extension through the Control Panel, I still get that annoying error message window each time I start ArcMap that tells me "3D Analyst has expired", so I want to remove the .dll or component that makes this happen. Thanks in advance and I will keep the answer this time or just break down and spend the small fortune to get the real extension.
Anthony
А вот так ему ответили:
http://support.esri.com/search/KbDocument.asp?dbid=21100"
"In windows explorer navigate to arcgis>arcexe82>utilities>Advanced ArcMap Settings, miscellaneous tab, and uncheck the License timeout warning box. This should fix your problem"
"Find the lincense folder and delete the 3D analyst license.
"Mine was located at C:\Program Files\ESRI\License\SingleUser"
Thanks again.
Надеюсь, это поможет вам
