Поддержка Visio, модели данных (+)
спросил 09 Ноя, 02 от Aleksey1 (1,420 баллов) в категории Сферы применения ГИС
Простите, что по-английски (если у кого трудности - сообщайте, будем переводить).
Алексей
Case tools support for XMI is now available for download at our external site. On www.esri.com go to Support -> click ArcGIS Desktop-> downloads (or directly http://support.esri.com/products/downloads/default.asp?p=28). This allows Visio 2002 Professional, as well as Visio 2000 Enterprise no longer available from Microsoft, to create Geodatabase repositories from UML.
For details about this, pls. go to the Secure Petroleum or Pipeline pages (via links in signature). There's a button if you don't remember your password. If you're not member please register under User Group Info (same links at bottom), it's free. Pls. request access and if you're a
Geodatasbe user then you'll get access to secure pages (same username/password).
Please note:
*     PPDM data models are posted under www.ppdm.org/products/spatial/index.html > Technical Downloads. PPDM has the PUG user list and you use your PPDM login there (PUG will inform PPDM of new members from time to time).
*     ArcGIS Pipeline Data Model (APDM) is posted on ESRI data model page www.esri.com/arcgisdatamodels (logical data model - diagram and description), and secure Pipeline page under Pipeline link @ bottom (physical data model - UML and repository). A sample data set will be added shortly.
ответил 16 Янв, 03 от Гость (210,080 баллов)
Кто-нибудь пробовал сгенерить из Visio 2002 Pro XMI? Поставил патч на Visio c microsoft, и Add-in от ESRI - результирующего файла не создается...
