Вешаешь на кнопочку следующую лабуду
(взято откуда-то из примеров или с их сайта):
Dim pDoc As IMxDocument
  Dim pMap As IMap
  Set pDoc = ThisDocument
  Set pMap = pDoc.FocusMap
  '-- Get the first layer
  Dim pFLayer As IFeatureLayer
  Set pFLayer = pMap.Layer(0)
  Dim pFc As IFeatureClass
  Set pFc = pFLayer.FeatureClass
  '-- Check to see if layer already has an area field
  If Not pFc.FindField("Area") = -1 Then
     MsgBox "Area already exists"
     Exit Sub
  End If
  '-- Create a field called Area
  Dim pField As IField
  Set pField = New Field
  Dim pFieldEdit As IFieldEdit
  Set pFieldEdit = pField
  With pFieldEdit
    .Name = "Area"
    .Type = esriFieldTypeDouble
    .Precision = 11
    .Length = 12
    .Scale = 3
  End With
  pFc.AddField pField
 '-- Loop through the features and get the area
  Dim pFCursor As IFeatureCursor
  Set pFCursor = pFLayer.Search(Nothing, False)
  Dim pFeat As IFeature
  Set pFeat = pFCursor.NextFeature
  Do Until pFeat Is Nothing
    Dim pArea As IArea
     If pFeat.Shape.GeometryType = esriGeometryPolygon Then
       Set pArea = pFeat.Shape
       pFeat.Value(pFc.FindField("Area")) = pArea.Area
       pFeat.Store
     End If
  Loop
