Нет, SDE как служба и отдельный дистрибутив большенебудетпоставляться.
http://downloads2.esri.com/support/TechArticles/W34229-DEPRECATION-PLAN-ARCGIS-10.4-10.3.1-090815.pd...[
Updated November 22, 2013] The ArcGIS 10.2 series of releases (ArcGIS 10.2, 10.2.1, and
10.2.2) will be the last releases that include the ArcSDE command line tools. Esri encourages
use of the new Geodatabase Administration dialog box in ArcCatalog and ArcMap and the
related geoprocessing tools that were introduced at 10.1.
o [
10.2.2) will be the last releases that include the ArcSDE application server. Esri encourages
those that have deployed an ArcSDE application server to move to new database
connections introduced in 10.1 as part of their next upgrade.
o [
10.2.2) will be the last releases that support the ArcSDE SDK with the ArcSDE C and Java
APIs. Other options are available for developers, including SQL, which is available as a result
of the widespread adoption of spatial types, the File Geodatabase API (introduced in 2011),
and ArcGIS Runtime SDKs that offer modern environments for the creation of compelling
custom applications.
Работать давно нужно с прямым подключением к СУБД.
http://desktop.arcgis.com/ru/desktop/latest/manage-data/gdbs-in-oracle/connect-oracle.htmhttp://desktop.arcgis.com/ru/desktop/latest/manage-data/gdbs-in-sql-server/connect-sqlserver.htmДля управления базой геоданных есть инструменты в arctoolbox и в ArcCatalog.
