Не знаю, как там в 10-ке, а в 9-й можно было бы начать с изучения примера "Create Point Features where Polylines Intersect", ну и дальше уже раскручивать это дело для полигонов.
How to use:
Select two intersecting polyline features.
Set the editor's target layer to a point feature class.
Paste the code into VBA and run the macro.
Public Sub CreatePointsFromIntersectingPolylines()
Dim pEditLayers As IEditLayers
Dim pEditor As IEditor
Dim pEnumFeature As IEnumFeature
Dim pFeature As IFeature
Dim pFeature2 As IFeature
Dim pGeomColl As IGeometryCollection
Dim pID As New UID
Dim pInvalidArea As IInvalidArea
Dim pPoint As IPoint
Dim pTopoOptr As ITopologicalOperator
Dim bInOperation As Boolean
Dim Count As Integer
On Error GoTo ErrorHandler
'Get a handle to the Editor extension
pID = "esriEditor.Editor"
Set pEditor = Application.FindExtensionByCLSID(pID)
Set pEditLayers = pEditor 'QI
If (Not pEditor.SelectionCount = 2) Or (Not pEditLayers.CurrentLayer.FeatureClass.ShapeType = esriGeometryPoint) Then
MsgBox "Must have exactly two polylines selected and Target Layer must be a point layer."
Exit Sub
End If
'Loop through the selected features to make sure we have polylines only
Set pEnumFeature = pEditor.EditSelection
pEnumFeature.Reset
Set pFeature = pEnumFeature.Next
Do While Not pFeature Is Nothing
If Not pFeature.Shape.GeometryType = esriGeometryPolyline Then
MsgBox "Both seleted features must be a polyline."
Exit Sub
End If
Loop
'Intersect the two polylines creating a multipoint
pEnumFeature.Reset
Set pFeature2 = pEnumFeature.Next
Set pTopoOptr = pFeature.Shape
Set pGeomColl = pTopoOptr.Intersect(pFeature2.Shape, esriGeometry0Dimension)
'If no intersection points, exit
If pGeomColl.GeometryCount = 0 Then Exit Sub
Set pInvalidArea = New InvalidArea
Set pInvalidArea.Display = pEditor.Display
'Create a new point features at each intersection
pEditor.StartOperation
bInOperation = True
For Count = 0 To pGeomColl.GeometryCount - 1
Set pPoint = pGeomColl.Geometry(Count)
Set pFeature = pEditLayers.CurrentLayer.FeatureClass.CreateFeature
Set pFeature.Shape = pGeomColl.Geometry(Count)
pFeature.Store
pInvalidArea.Add pFeature
Next Count
pEditor.StopOperation ("Create Points from Intersections")
bInOperation = False
'Refresh the display
pInvalidArea.Invalidate esriAllScreenCaches
Exit Sub 'Exit to avoid error handler
ErrorHandler:
If bInOperation Then
pEditor.AbortOperation
End If
End Sub
