Помогите исправит код
спросил 16 Окт, 12 от kog9 (400 баллов) в категории Программные продукты Esri
    Помогите пожалуйста ни как не могу понять в чем проблема!!!
Public Sub CreateShapefile()
Dim pFSO As Object, sFCName As String
sFCName = "d:\temp\myshape.shp" 'файл без имени
Set pFSO = CreateObject("Scripting.FileSystemObject")
Dim pFWS As IFeatureWorkspace
Dim pWorkspaceFactory As IWorkspaceFactory
Set pWorkspaceFactory = New ShapefileWorkspaceFactory
Set pFWS = pWorkspaceFactory.OpenFromFile("d:\temp", 0)
Dim pFields As IFields
Dim pFieldsEdit As IFieldsEdit
Set pFields = New Fields
Set pFieldsEdit = pFields
Dim pField As IField
Dim pFieldEdit As IFieldEdit
Set pField = New Field
Set pFieldEdit = pField
pFieldEdit.Name = strShapeFieldName
pFieldEdit.Type = esriFieldTypeGeometry
Dim pGeomDef As IGeometryDef
Dim pGeomDefEdit As IGeometryDefEdit
Set pGeomDef = New GeometryDef
Set pGeomDefEdit = pGeomDef
With pGeomDefEdit
.GeometryType = esriGeometryPoint
Set .SpatialReference = New UnknownCoordinateSystem 'система кординат
End With
Set pFieldEdit.GeometryDef = pGeomDef
pFieldsEdit.AddField pField
With pFieldEdit
.Length = 30
.Name = "НАПРАВЛЕНИЕ"
.Type = esriFieldTypeString
End With
With pFieldEdit
.Length = 30
.Name = "СКОРОСТЬ"
End With
Set pFeatClass = pFWS.CreateFeatureClass(strName, pFields, Nothing, _
Nothing, esriFTSimple, strShapeFieldName, "")
End Sub
Public Sub AddShapeFile()
Dim pFeatureWorkspace As IFeatureWorkspace
Dim pFeatureLayer As IFeatureLayer
Dim pMxDocument As IMxDocument
Dim pMap As IMap
Set pFeatureWorkspace = pWorkspaceFactory.OpenFromFile("D:\Temp", 0)
Set pFeatureLayer = New FeatureLayer
Set pFeatureLayer.FeatureClass = pFeatureWorkspace.OpenFeatureClass("")
pFeatureLayer.Name = pFeatureLayer.FeatureClass.AliasName
Set pMxDocument = Application.Document
Set pMap = pMxDocument.FocusMap
pMap.AddLayer pFeatureLayer
End Sub
Public Sub StartEditing()
Dim pEditor As IEditor
Dim pID As New UID
Dim pDataset As IDataset
Dim pMap As IMap
Dim pMxDoc As IMxDocument
Dim LayerCount As Integer
Set pMxDoc = Application.Document
Set pMap = pMxDoc.FocusMap
pID = "esriCore.Editor"
Set pEditor = Application.FindExtensionByCLSID(pID)
If pEditor.EditState = esriStateEditing Then Exit Sub
'Start editing the workspace of the first featurelayer you find
For LayerCount = 0 To pMap.LayerCount - 1
If TypeOf pMap.Layer(LayerCount) Is IFeatureLayer Then
Set pFeatureLayer = pMap.Layer(LayerCount)
Set pDataset = pFeatureLayer.FeatureClass
pEditor.StartEditing pDataset.Workspace
Exit For
End If
Next LayerCount
End Sub
Public Sub AddPoint()
Dim edit As IEditSketch
Dim p As IPoint
Set edit = pEditor
Set p = New Point
Dim x As Double
Dim y As Double
x = 61472491264#
y = 27120216734#
p.PutCoords x, y
edit.AddPoint p, True
End Sub
Public Sub ExtractValuesToPoints()
Dim pointDataset As IGeoDataset
Dim valueRaster As IGeoDataset
Dim pExtractionOp As IExtractionOp2
Set pExtractionOp = New RasterExtractionOp
Dim pRas01 As IRaster
Set pRas01 = readRasterFromDisk("c:\data\myRaster1")
Dim pFC01 As IFeatureClass
Set pFC01 = readPointFeatureFromDisk("d:\temp\.shp")
Dim pOutGeoDS As IGeoDataset
Set pOutGeoDS = pExtractionOp.ExtractValuesToPoints(pFC01, pRas01, True)
11 Ответы
ответил 16 Окт, 12 от kog9 (400 баллов)
readRasterFromDisk и эта readPointFeatureFromDisk почему эта функция не определена
Dim p As IPoint
Set edit = pEditor
Set p = New Point
Dim x As Double
Dim y As Double
x = 61472491264#
y = 27120216734#
p.PutCoords x, y
End Sub И ПОЧЕМУ ВЫДАЕТ ОШИБКУ ОБЪЕКТ НЕ НАЙДЕН
Ребята помогите пожалуйста
ответил 17 Окт, 12 от new_sergei (2,660 баллов)
Dim p As IPoint
Set edit = pEditor
Set p = New Point
Dim x As Double
Dim y As Double
x = 61472491264#
y = 27120216734#
p.PutCoords x, y
Так а где сама функция readRasterFromDisk?
Она есть у вас? Вы полный свой код привели? Или это из какого-то примера?
ответил 17 Окт, 12 от kog9 (400 баллов)
http://edndoc.esri.com/arcobjects/9.2/net/shared/geoprocessing/spatial_analyst_tools/extract_values_to_points.htm
Эта часть копировалась от сюда
Нет в библиотеках найти ее не удалось.
Код полный
Код полный
Дело в том, что в библиотеках этой функции не будет. Это функция, которая была создана самим пользователем (программистом). Вам тогда надо поискать в других примерах на edndoc где может быть такая функция, или самому написать свою такую функцию, которая бы возвращала IRaster. Для этого тоже надо посмотреть примеры.
Т.е., ошибка у Вас в том, что вы пытаетесь вызвать функцию, которая не является системной, а созданна должна быть именно Вами.
Спасибо буду искать может вы подскажете почему в этом фрагменте вылетает ошибка (Объект не найден)
Dim p As IPoint
Set edit = pEditor
Set p = New Point
Dim x As Double
Dim y As Double
x = 61472491264#
y = 27120216734#
p.PutCoords x, y
End Sub
Сеанс редактирование запущен , объект создан а точку все равно добавлять не хочет
ответил 18 Окт, 12 от new_sergei (2,660 баллов)
Dim p As IPoint
Set edit = pEditor
Set p = New Point
Dim x As Double
Dim y As Double
x = 61472491264#
y = 27120216734#
p.PutCoords x, y
End Sub
edit проинициализировался правильно?
ответил 19 Окт, 12 от kog9 (400 баллов)
Вроде бы да ошибка вылетает на edit.AddPoint p, True
но компилятор встроенный ArcGis муть
ответил 19 Окт, 12 от new_sergei (2,660 баллов)
Сейчас доступа к ArcGis нет, поэтому не могу точно сказать. А точно есть такая функция у этого интерфейса? Может, пример для другой версии был, а в той версии, в которой Вы пробуете его запустить, функция может по-другому называться. Проверьте.
