If you relate to a table that does not have an ObjectID column (such as delimited text files or OLE DB tables), you will not be able to apply selections using the relate. The Related Tables command from the table window's Options menu will list the relate, but it will be unavailable. The Identify tool, however, can still be used to find related records
Если не понятно, то могу перевести.
