Итак, оно свершилось - мне приходится администрировать ArcGIS Server 10.0.
Не то что я всю жизнь мечтал налаживать онлайн сервисы.
Увы, программа не дорабатывает прямо с начала. Сервер вообще не виден, пока ArcSOC.exe и ArcSOM.exe не были добавлены в исключения брандмауэра.
Теперь сервер виден и к нему можно присоединиться, но в АркКаталоге карта пустая (хотя при движении мыши внизу видны географические координаты).
Ситуация встречается, но уклончиво описывается в документации сервера, типа возможны проблемы с работой виртуальных директорий. Но никаких рецептов не предлагается.
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/Common_problems_and_solutions/0093000001mq000000/I'm trying to preview a map service in ArcCatalog, but the image is blank.
If you see a blank Preview
tab with coordinate values appearing below as you move the mouse, it's
likely that ArcCatalog can't get the map image from the virtual
directory you have associated with your output directory. In this
situation, ArcCatalog has all the information about the map except for
the actual image, which is why you see the coordinates as you move the
mouse. The best chance of fixing the problem is to check the virtual
directory settings using your Web server administration software, making
sure that the virtual directory is correctly pointing to the output
directory on disk.
If you want to verify
that the problem is with the output directory, adjust the map service's
properties so that the supported image return type is MIME only. This
setting does not use an output directory. If you see the image with MIME
only and you don't see it with MIME + URL, then you know there is a
problem with the output directory and/or the virtual directory.
You can browse to the
output directory on disk to make sure that the images are being created
inside. If you see images being added to the output directory as you try
to preview the map service, then the problem is with the virtual
directory settings.
Изменение image return type на MIME ничего не меняет.
Буду благодарен если кто-то разбирается в этой проблеме. Очень хочется видеть географические объекты на экране. Сисадминовская возня начинает попахивать дружелюбным миром Unix.
Windows Server 2008 R2 на виртуальной машине, соединение ArcCatalog идёт с машины Windows 7 Pro, та же учётная запись.
