ArcGIS 10.0 SP2 - will to be available April 28th
спросил 27 Апр, 11 от PITKS1 (20,860 баллов) в категории Программные продукты Esri
ArcGIS Desktop
ArcGIS General:
NIM056609 - MapDoc.dataDrivenPages throws a poor error when the map document is not DDP enabled.
NIM058851 - <I18N> Alternating Scale Bar fills in solid black when zooming in.
NIM061933 - Multi-ring Buffer tool clips output buffers if Dissolve: All is specified.
NIM062577 - When running Mean center on data with all negative values for a particular case, the tool fails.
NIM062580 - Ripleys K fails with the Reduce or Ripley Correction methods if user-provided parameter values produce an empty study area polygon. The error message provided isn't helpful.
NIM062715 - Add Geoprocessing History page to FGDC metadata style.
NIM062716 - Add Service Details page to NAP metadata style configuration.
NIM063159 - Import ArcEngine doesn't set the 'engine' product which causing the script to run with the highest available license.
NIM063208 - ESRI-ISO_template.xml writes data quality report information to the wrong tag: dqReport instead of report.
NIM063797 - “The item's XML contains errors” displayed in ArcCatalog Description Tab when viewing .xml metadata generated using XSLT Transformation Tool and using the “generate metadata template.xslt” as Input XSLT Transformation Tool.
NIM063852 - The service pack information does not appear in the help > about box; the Desktop applications are pointing to the wrong registry information.
NIM063958 - Handle & and other xml escaped characters properly in AddIn info element nodes.
NIM064292 - Using output coordinate system seems to work, but the calculated search threshold seems to ultimately be interpreted in the input coordinate system units.
NIM064293 - Please return as derived output the SOURCEID fieldname to make it easier to join field input feature class attributes to output feature class results.
NIM064430 - There are problems exporting some distribution information and multiple processors associated with a process step lineage from ArcGIS to ISO 19139. There are problems importing many citation dates and some spatial reference properties to ArcGIS from ISO 19139.
NIM064532 - Remove machine names from an item's metadata.
NIM064551 - Run MultipleRingBuffer as a GP service crashes the server objects due to imtermediate output not set up correctly in the script.
NIM064644 - Update ArcGIS Server .NET Help for 10.0 SP2.
NIM064645 - Update ArcGIS Server Java Help for 10.0 SP2.
NIM064646 - Update ArcIMS Web Manager Java Help for 10.0 SP2.
NIM064652 - Update the Military Styles with missing APP6B symbolsUpdate the Military Styles with missing APP6B symbols.
NIM064668 - Raise a more helpful message when calling MapDocument.saveACopy on an already-open or read-only MXD.
NIM064675 - General GML elements used to describe units of measure,times, points, and polygons in metadata are handled incorrectly when importing and exporting between ArcGIS metadata and the ISO 19139 format.
NIM064689 - Update popup stylesheets to display Chinese characters.
NIM064990 - The first 2 links in the Help > About on Windows 7 only, do not work. The 3rd one does.
NIM065087 - Documentation updates for ArcGIS 10.0 SP2.
ArcGIS\3DAnalyst\3DAnalyst:
NIM052617 - The Snap Raster option should be honored by the Tin to Raster (gp) tool.
NIM062611 - Surface Contour will return, "Error 050079: The index interval must be evenly divisible by the contour interval." when the Contour Interval is set to 0.2 and an Index Interval is set even when the Index Interval can be evenly divisible by the 0.2.
ArcGIS\ArcGISCommonFiles:
NIM065915 - Extract package GP tool is not working in 10 SP2 build # 3200.
ArcGIS\BeagleGraphicc:
NIM064020 - Along Line marker placement style for Representations is not equivalent when published to MSD.
ArcGIS\Cadastral\CadastralUI:
NIM043705 - A line string construction can not be deleted via the construction tool context menu. It can be deleted in the grid by deleteing the row or splitting the line string.
NIM059976 - For Scale and Rotation, the stated area needs to be calculated during the topo importer process.
NIM060385 - Selection on Control does not fill in the control dialog.
NIM060389 - When creating a schema-only layer package that includes a Parcel Fabric and a .lyr file (built from a sub-class), the .lyr file has a broken data source when un-packed.
NIM060390 - Using the Merge Two Point tool and Merge Points w/in Rectangle tool creates vectors that results in undesirable feature class adjustment outcomes.
NIM060395 - Ignore VCS speciifed on append, reports DATUM mismatch.
NIM061656 - Concurrent editing of Parcel Fabric within separate child versions of Default hangs other edit sessions when the Modify command is used.
NIM062527 - Planarize on parallel offset does not break line if offset line is perpendicular to parent line.
NIM062788 - Topology loader fails to load certain parcels incorrectly defining them as multi-part.
NIM062789 - All Parcel Editor dialogs should use field aliases from the database.
NIM062864 - Origin Connection sequenced incorrectly.
NIM063175 - Unjoined Parcel Groups need to persist expanded or condensed in Parcel Explorer.
NIM063176 - Blow out circular curve created for a donut parcel.
NIM063177 - Remove button on a previously created job is broken.
NIM063178 - Parcel Explorer window disabled. Can not recover unless ArcMap is restarted.
NIM063180 - Deleting a Control Point should remove its association to the Name field on its formerly associated point.
NIM063185 - Parcel polygon not in sync with parcel line-work after linepoint ******ing has been preformed.
NIM063186 - Parcel Remainder does not work on a parcel participating in a separate layer file if it is queried out of the default Parcels layer.
NIM063187 - Crash when deleting join links.
NIM063188 - Set plan on Merge causes tool to not work.
NIM063189 - ArcMap crashes when using the Make Feature Layer GP tool on a parcel fabric sublayer.
NIM063190 - Import of unclosed parcels results in missing data.
NIM063192 - No map refresh when zoom to extent of parcel.
NIM063193 - Curve with 180 degree delta needs a better error message.
NIM063195 - Can not change the plan during a construction.
NIM063196 - Copy and paste CAD lines results in construction lines being mangled.
NIM063197 - Unjoined, unclosed parcels line segments are reversed.
NIM063329 - Parcels are not being loaded via Topoloader if there are small line segments that fall within a tolerance.
NIM063629 - DBMS Error when merging points on SDE database.
NIM064390 - Enable selection chip for Parcel Edit tool.
NIM064435 - Duplicating parcels in an unjoined group should create a new group.
NIM064444 - Loading Unclosed parcels should create buffer geometry.
NIM064491 - Plan Directory needs to allow multi-select.
NIM064492 - TopoLoad, unclosed parcels fail when source GDB is different.
NIM064493 - Parcel Explorer does not empty its contents after removing fabric layer.
NIM064494 - Need a better message when locking message appears.
NIM064495 - Not able to import parcels with connection lines into an unjoined group.
NIM064536 - Line-strings get "flattened" on update.
NIM064877 - Using breakpoints and saving construction results in mangling.
ArcGIS\Catalog:
NIM061743 - ArcMap creates thousands of default.gdb files on startup and eventually fails to start.
ArcGIS\Catalog\CatalogUI\CAD:
NIM060275 - There is a hard coded string "No Default World File" in Coordinate dia
8 Ответы
ответил 28 Апр, 11 от Dorofeev1 (6,460 баллов)
Ого, впечатляющий список, может после сервис пака это решето можно будет использовать. Пока, к сожалению, ArcGIS 10 SP1 не прижился
ответил 28 Апр, 11 от geouser (9,040 баллов)
Я с ужасом думаю, когда окончательно придётся переходить на десятку. Ощущение подлянки из-за угла никуда не исчезло, продолжаю основную работу делать на 9.3.1.
ответил 03 Май, 11 от Holger (19,360 баллов)
Судя по списку исправлений есть вероятность СП3 :).
ответил 03 Май, 11 от Dorofeev1 (6,460 баллов)
Да там багов на 6 Service Pack`ов хватит, но я думаю они быстрей выпустят 10.1, где будет немного нового функционала, и куча багфикса.
В  смысле готовьте денежки на ТП 2012 :) ?
Т.е. версия про "несчастливые" чётные номера версий подтверждается :(.
Кстати, есть кто-нибудь, кто сел на новый релиз сразу по его выходу?
Я не знаю как насчет четных версий, но складывается впечатление что все минорные релизы - это по большей части багфикс за деньги.
ответил 04 Май, 11 от PITKS1 (20,860 баллов)
SP3 будет ближе к осени. Вобще сервиспаки по расписанию теперь идут. 3-4 в год :-)
ответил 05 Май, 11 от Holger (19,360 баллов)
Значит ли это, что 10 доведут до ума, а исправление от её багов не перейдёт на 10.1?
