Добрый день.
Требуется при открытии автоматически подсветить и позиционировать карту по требуемому объекту, нашёл пример:
protected void ZoomToFeature(string key, string layer)
ESRI.ArcGIS.ADF.Web.DataSources.IMS.MapFunctionality mf;
ESRI.ArcGIS.ADF.IMS.Carto.MapView mv;
mf = (ESRI.ArcGIS.ADF.Web.DataSources.IMS.MapFunctionality)Map1.GetFunctionality(0);
mv = mf.MapView;
ESRI.ArcGIS.ADF.IMS.Carto.Layer.FeatureLayer queryLayer;
queryLayer = (FeatureLayer)mv.Layers.FindByName(layer);
Filter queryFilter = new Filter();
QueryParameters queryParams = new QueryParameters(queryFilter);
queryFilter.WhereExpression = "ObjectID = '" + key + "'";
queryFilter.Tolerance = 20;
queryFilter.ToleranceUnits = BufferUnits.Meters;
queryParams.ReturnGeometries = true;
queryParams.ReturnGlobalEnvelope = true;
ESRI.ArcGIS.ADF.IMS.Display.Symbol.FeatureSymbol fs = new ESRI.ArcGIS.ADF.IMS.Display.Symbol.SimpleFillSymbol(System.Drawing.Color.White, System.Drawing.Color.Red, ESRI.ArcGIS.ADF.IMS.Display.Symbol.PolygonFillType.Solid);
ESRI.ArcGIS.ADF.IMS.Display.Renderer.SimpleRenderer sr = new ESRI.ArcGIS.ADF.IMS.Display.Renderer.SimpleRenderer(fs);
queryLayer.Visible = true;
FeatureTable ft = queryLayer.Query(queryParams);
if (ft.Rows.Count > 0)
ESRI.ArcGIS.ADF.IMS.Geometry.Geometry featureGeom = (ESRI.ArcGIS.ADF.IMS.Geometry.Geometry)ft.Rows[0]["#SHAPE#"];
ESRI.ArcGIS.ADF.Web.Geometry.Geometry adfGEom = ESRI.ArcGIS.ADF.Web.DataSources.IMS.Converter.ToADFGeometry(featureGeom);
ESRI.ArcGIS.ADF.Web.Geometry.Envelope adfEnv = ESRI.ArcGIS.ADF.Web.Geometry.Envelope.GetMinimumEnclosingEnvelope(adfGEom);
Map1.Extent = adfEnv;
Map1.Refresh();
Копирую функцию в Default.aspx.cs, получаю следующее:
CS0234: The type or namespace name 'IMS' does not exist in the namespace
'ESRI.ArcGIS.ADF' (are you missing an assembly reference?)
Line 87: ESRI.ArcGIS.ADF.IMS.Carto.MapView mv;
Версия сервера 9.3. Как адаптировать этот пример, или дело не в версии?
Спасибо за внимание.
