Oracle Spatial 11g:
спросил 26 Янв, 10 от Dido_kz1 (11,020 баллов) в категории Программные продукты Esri
Один из документов написано так:
<!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:204; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:204; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.Msonormal, li.Msonormal, div.Msonormal {mso-style-unhide:no; mso-style-qat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-:EN-US;} .MsoChpDefault {mso-style-:ex-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-:EN-US;} .MsoPapDefault {mso-style-:ex-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:612.0pt 792.0pt; margin:2.0cm 42.5pt 2.0cm 3.0cm; mso-er-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]> <> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} <![endif]-->Oracle Spatial является опцией к Oracle Database 11g Enterprise Edition с полной поддержкой 3D и веб-сервисов для управления всеми геопространственными данными, в том числе векторными и растровыми данными, топологиями и сетевыми моделями
А вот скажите, ведь у нас SDE работает не только с Enterprise, так же со Standart, Personal Edition, получается ESRI не использует приимуществ Oracle? по своему хранить... Нужен ли для работы или для отимизаций ArcGIS этот модуль ? На практике используется вообще ?
ответил 27 Янв, 10 от PITKS1 (20,860 баллов)
Как это "не использует". SDE может хранить данные в Oracle Spatial формате или в своем. Если клиенты используют софт других фирм который может читать Oracle Spatial - есть смысл хранить в нем. В противном случае - в SDE формате. Быстрее работает.
ответил 28 Янв, 10 от Dido_kz1 (11,020 баллов)
а где опция для этого, если модуль Oracle Spatial включен, т.е  SDE автоматическийв формате Oracle Spatial хранить ???? или где то опциях есть ? Вы считаете что SDE быстрее работает ? Пока для меня все это темная сторона... :-)
ответил 29 Янв, 10 от PITKS1 (20,860 баллов)
Когда создается SDE репозиторий можно выбрать в каком формате хранить данные.
ответил 29 Янв, 10 от Dido_kz1 (11,020 баллов)
спс, поюзаю....
