данные формате .pmf, .sdc, .sdi
спросил 15 Ноя, 09 от aldggl (260 баллов) в категории Программные продукты Esri
данные формате .pmf, .sdc, .sdi - как конвертировать данные?
есть данные - в формате .pmf, .sdc, .sdi
нужно конвертировать их из этих форматов в мапинфо, арквью
.pmf - в аркреадере открывается с глюком - там слои отмечены звездочкой - (так бывает при не правильных ссылках на слой) - чем это поправить я так и не нашел в реадере. поэтому стал вопрос -
- как из данных .pmf, .sdc, .sdi получить нормальные данные в формате шейп и таб?
ответил 15 Ноя, 09 от PITKS1 (20,860 баллов)
SDC feature classes differ in respect to other ArcGIS feature classes because they support multiple geometries for a single record. This design feature allows the storage of generalized versions of detailed geometry with only one set of attribute information. They support a licensing mechanism which can be used to bind access to a specific ArcGIS application, such as ArcReader or to a specific extension such as ArcGIS Business Analyst.
SDC feature classes are created using ESRI's Data Development Kit Professional (DDKP). They are composed of an SDC file that stores both geometry and data, a spatial index (.sdi) file that represents the spatial index, an attribute index descriptor (.idi) file that is a pointer to attribute indexes, and any number of attribute indexes that are defined in the IDI file. Filename extensions for individual attribute indexes are open as long as they are correctly defined in the IDI file.
SDC feature classes can only be used as input to geoprocessing tools that produce a distinct output or tools that update attributes. They cannot be used by those tools that update the geometry of the input.
If you want to update the geometry of an SDC feature class, export it to a geodatabase feature class and perform updates to the geometry of the geodatabase feature class. In the Conversion Tools toolbox, click the To Geodatabase toolset and use the Feature Class To Feature Class tool or the Feature Class to Geodatabase tool (for multiple inputs) to convert SDC feature classes into geodatabase feature classes.
In the Search tab of the ArcToolbox window, type "feature class" to locate tools that work with SDC feature classes.
ответил 18 Ноя, 09 от Grigoriy (127,020 баллов)
pmf - это не данные. Это проект подготовленный для публикации с помощью ArcGIS publisher.
Он не редактируется по определению. А тем более в ArcReader. Он создается заново. Для этого нужен ArcGIS Desktop + Publisher.
Если потеряны пути к данным, то всё что Вы можете сделать это попытаться положить данные в нужное место.
Формат SDC также специально разработан для передачи конечным пользователям. Данные в этом формате более компактны и хорошо проиндексированы для быстрой работы.
Данные SDI могут быть сконвертированы как в шейп-файлы, так и в базу геоданных стандартными средствами ArcGIS Desktop, но при условии, что поставщик данных не закрыл эту возможность.
Т.е. если Вы можете просматривать такие данные с помощью ArcMap или ArcCatalog, то сможете и сконвертировать их.
ответил 19 Ноя, 09 от aldggl (260 баллов)
спасибо за помощь. .pmf захотел открываться только в arcreadere
а как открыть их?
