Калькулятор посмотрел, да, много чего сделано! но поздно посмотрел...
Вот мое первое приближение:
Option Explicit
Private Sub UIButtonControl1_Click()
   Dim pMxDoc As IMxDocument
   Set pMxDoc = ThisDocument
   Dim pUID As New UID
   pUID = "{E156D7E5-22AF-11D3-9F99-00C04F6BC78E}" 'IGeoFeatureLayer IID
   Dim pEnumLayer As IEnumLayer
   Set pEnumLayer = pMxDoc.FocusMap.Layers(pUID, True)
   pEnumLayer.Reset
   Dim pFeatureLayer As IFeatureLayer
   Dim pFeatureSelection As IFeatureSelection
   Dim pFeatureCursor As IFeatureCursor
   Dim pFeature As IFeature, pFT2 As IFeature
   Dim pArea As IArea, pCurve As ICurve
   Dim dTotalArea As Double, dTotLen As Double
   Set pFeatureLayer = pEnumLayer.Next
   Do Until (pFeatureLayer Is Nothing)
      If (pFeatureLayer.FeatureClass.ShapeType = esriGeometryPolygon Or pFeatureLayer.FeatureClass.ShapeType = esriGeometryPolyline) Then
         Set pFeatureSelection = pFeatureLayer
         If (pFeatureSelection.SelectionSet.Count <> 0) Then
            pFeatureSelection.SelectionSet.Search Nothing, True, pFeatureCursor
            Set pFeature = pFeatureCursor.NextFeature
            Do Until (pFeature Is Nothing)
                If TypeOf pFeature.Shape.SpatialReference Is IGeographicCoordinateSystem Then
                    If (pFeatureLayer.FeatureClass.ShapeType = esriGeometryPolygon) Then
                        Set pArea = FeatureProj(pFeature)
                        dTotalArea = dTotalArea + pArea.Area
                    End If
                    If (pFeatureLayer.FeatureClass.ShapeType = esriGeometryPolyline) Then
                        Set pCurve = FeatureProj(pFeature)
                        dTotLen = dTotLen + pCurve.Length
                    End If
                End If
            Loop
         End If
      End If
   Loop
   MsgBox "Общая длина, М = " & CStr(dTotLen) & vbCrLf & "Общая площадь, м2 = " & CStr(dTotalArea)
End Sub
Function FeatureProj(pFeat As IFeature) As IGeometry
    Dim pSpatialReferenceEnv As SpatialReferenceEnvironment
    Set pSpatialReferenceEnv = New SpatialReferenceEnvironment
    Dim pFromSR As ISpatialReference
    Set pFromSR = pSpatialReferenceEnv.CreateGeographicCoordinateSystem(esriSRGeoCS_WGS1984)
    Dim pToSR As ISpatialReference
    'Set pToSR = pSpatialReferenceEnv.CreateProjectedCoordinateSystem(esriSRProjCS_WGS1984UTM_42N)
    Set pToSR = pSpatialReferenceEnv.CreateProjectedCoordinateSystem(GetPCS(pFeat.Shape.Envelope))
    Dim pGeo As IGeometry
    Set pGeo = pFeat.ShapeCopy
    pGeo.Project pToSR
    Set FeatureProj = pGeo
End Function
Function GetPCS(env As IEnvelope) As Long
    Dim pp As IPoint, ar As IArea
    Set ar = env
    Set pp = ar.Centroid
    Dim d As Double, ai As Long, rl As Long
    ' 32600 - esriSRProjCS_WGS1984UTM N
    ' 32700 - esriSRProjCS_WGS1984UTM S
    d = pp.X / 6
    ai = Round(d)
    rl = ai + IIf(pp.Y > 0, 32600, 32700) + 30
    GetPCS = rl
End Function
есть ошибка миллиметровая, не пойму почему!?
