Когда создаю ArcWeb Services
появляется окно -
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: #{resources.addArcWebServer}: javax.faces.el.EvaluationException: /applications/resources.xhtml @653,166 action="#{resources.addArcWebServer}": javax.management.RuntimeMBeanException
javax.faces.webapp.FacesServlet.service(FacesServlet.java:209)
com.esri.arcgis.manager.web.util.ManagerWebFilter.doFilter(Unknown Source)
com.esri.arcgis.manager.web.util.FileUploadFilter.doFilter(Unknown Source)
root cause
javax.faces.FacesException: #{resources.addArcWebServer}: javax.faces.el.EvaluationException: /applications/resources.xhtml @653,166 action="#{resources.addArcWebServer}": javax.management.RuntimeMBeanException
com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:78)
javax.faces.component.UICommand.broadcast(UICommand.java:312)
javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:267)
javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:381)
com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:75)
com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:200)
com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:90)
javax.faces.webapp.FacesServlet.service(FacesServlet.java:197)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.9 logs.
