Помощь новичку!!! Кто желает???
спросил 22 Окт, 08 от most.of (400 баллов) в категории Программные продукты Esri
<!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-at:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:204; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.Msonormal, li.Msonormal, div.Msonormal {mso-style-unhide:no; mso-style-qat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoChpDefault {mso-style-:ex-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoPapDefault {mso-style-:ex-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:612.0pt 792.0pt; margin:2.0cm 42.5pt 2.0cm 3.0cm; mso-er-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]> <> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} <![endif]-->
Помогите пожалуйста мне решить парочку вопросов.
Первый вопрос.
Как подписать горизонтали с разрывом линии ?
Вот в этой карте например:
Второй вопрос.
Как построить изолинии или грид в определённых границах?
Например, надо построить изолинии в этих границах (розовая линия)
Я только начел осваивать ArcGIS, поэтому прошу тех кто будет отвечать, давать как можно подробные ответы.
Заранее БЛАГОДАРЮ!!!
6 Ответы
ответил 22 Окт, 08 от sgmv (2,180 баллов)
По первому вопросу: Создайте буфер вокруг надписи с белой заливкой.
ответил 22 Окт, 08 от dashat1 (820 баллов)
    1. Надписи не имеют постоянного местоположения. Поэтому сначала их надо конвертировать в аннотации, а потом создать Контурные маски (по сути те же буферы) (инструмент маскирования доступен в ArcInfo). Потом через свойства фрейма применить маскирование по "буферным" полигонам для слоя изолиний.
ответил 23 Окт, 08 от Vadim (28,120 баллов)
По второму вопросу:
Используйте Spatial Analyst. Options=>General=>Analysis mask.  Options=>Extent=>Anallysis extent
ответил 23 Окт, 08 от most.of (400 баллов)
dashat и 1gerzog создание маски не решение так как фон как видно на рисунке не одинаковый.
или я что то путаю?
"По второму вопросу:
Используйте Spatial Analyst. Options=>General=>Analysis mask.  Options=>Extent=>Anallysis extent"
спасибо большое, завтра попробую!
ответил 23 Окт, 08 от dashat1 (820 баллов)
    Можно маскировать только изолинии
Фон не пострадает
    upd: Для этого маски должны быть отдельным полигональным слоем
я дезинформировала насчет Свойств фрейма, простите
Память подвела ))
Нужно идти не в свойства, а в Расширенные опции рисования
(Нажмите правой кнопкой на название фрейма (Слои, по умолчанию) и выберите из списка те самые Расширенные опции)
Там сразу все поймете
