Доступ к выделенным объектам
спросил 28 Июль, 08 от Scrama (880 баллов) в категории Программные продукты Esri
    Наиболее близкое, что нашел в справке:
ArcMap has two different selections, a feature selection and an element selection. Two different objects represent these selections and both implement the ISelection interface. The feature selection object additionally implements IEnumFeature and the element selection object IEnumElement. The ISelection interface is used for clipboard type operations and the IEnum interfaces are used to loop through the items in the collection.
When you ask for the FeatureSelection from IMap you are returned an ISelection but you can perform a query interface for IEnumFeature and usually do so. However, if you get the selection via IActiveView::Selection, the selection can either be an element selection or a feature selection depending on which one is currently active - only one of the selections can be active at a time. Use FeatureSelection to ensure a reference to the correct selection.
IEnumFeature works on all of the FeatureLayers as a whole. Each FeatureLayer has a ISelectionSet and IEnumFeature steps through all of these as though there was only one. Because IEnumFeature works with all the FeatureLayers, you cannot use it to loop through the features belonging to just one FeatureLayer.
Note, only the shape field is guaranteed with the selection. This is the default and exists for performance reasons. The IMap::FeatureSelection property is typically used to draw the map selection, not access feature attributes. This is particularly noticeable with shapefiles and coverage but also in geodatabases if the selection is large enough. Use IEnumFeatureSetup::AllFields to set a flag indicating all fields be returned with the selection. If you want to loop through the map selection to perform an operation, it is typically best to access each layer's selection rather than the entire map's selection. See the example for a sample of each.
Из всего этого я так и не понял, как мне получить доступ к IEnumFeatures имея в своем распоряжении IDocument и IApplication.
Нужно пробежаться по свойствам объектов, выбранным пользователем. Использую VC++
ответил 29 Июль, 08 от Scrama (880 баллов)
Все, проблему решил сам.
А как узнать, к какому IFeatureLayer принадлежит IFeature?
ответил 30 Июль, 08 от Scrama (880 баллов)
Получается, что только перебором - обратной связи IFeature-IFeatureLayer не реализовано.
