SDE + MS SQL ERROR
спросил 30 Июнь, 08 от 2bars (440 баллов) в категории Программные продукты Esri
вообщем при установки ArcSDE на этапе где указывается сервер sql и имя базы данных и метод аутентификации вылазиет окно об ошибке открываю лог... sp3 поставил... что делать? как быть ?
WARNING: Parameter "TEMP" not found in defaults file!
WARNING: Setting TEMP to "C:\DOCUME~1\9335~1\LOCALS~1\Temp"
VERSION table created...
SPATIAL_REFERENCES table being created...
SPATIAL_REFERENCES table created...
GEOMETRY_COLUMNS table being created...
GEOMETRY_COLUMNS table created...
LAYERS table being created...
LAYERS table created...
METADATA table being created...
METADATA table created...
RASTER_COLUMNS table being created...
RASTER_COLUMNS table created...
TABLE_REGISTRY table being created...
TABLE_REGISTRY table created...
STATES table being created...
STATES table created...
VERSIONS table being created...
VERSIONS table created...
MVTABLES_MODIFIED table being created...
MVTABLES_MODIFIED table created...
STATE_LINEAGES table being created...
STATE_LINEAGES table created...
LOCATORS table being created...
LOCATORS table created...
XML tables being created...
XML tables created...
COLUMN_REGISTRY table being created...
COLUMN_REGISTRY table created...
DBTUNE table being created...
DBTUNE table created...
SERVER_CONFIG tables being created...
SERVER_CONFIG tables created...
LOGFILE_POOL tables being created...
LOGFILE_POOL tables created...
DBMS stored procedures being created or updated...
DBMS stored procedures created or updated...
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'B_STORAGE'.
    Inserting the default values.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'F_STORAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'S_STORAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'A_STORAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'D_STORAGE'.
WARNING: dbtune.sde does not contain DEFAULTS config parameter 'GEOMETRY_STORAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_DOC_INDEX'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_DOC_STORAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_STORAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_INDEX_PK'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_INDEX_ID'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_INDEX_TAG'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_INDEX_DOUBLE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_FULLTEXT_CAT'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_FULLTEXT_LANGUAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_FULLTEXT_UPDATE_METHOD'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_DOC_TEXT_IN_ROW'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_TEXT_IN_ROW'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_CLUSTER_PK'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_CLUSTER_ID'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_CLUSTER_TAG'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_CLUSTER_DOUBLE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'XML_IDX_FULLTEXT_TIMESTAMP'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'RAS_STORAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'BND_STORAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'AUX_STORAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'BLK_STORAGE'.
WARNING: File dbtune.sde does not contain DEFAULTS config parameter 'PERMISSION_CACHE_THRESHOLD'.
WARNING: File dbtune.sde does not contain LOGFILE_DEFAULTS config parameter 'LF_STORAGE'.
WARNING: File dbtune.sde does not contain LOGFILE_DEFAULTS config parameter 'LD_STORAGE'.
WARNING: File dbtune.sde does not contain LOGFILE_DEFAULTS config parameter 'SESSION_TEMP_TABLE'.
WARNING: File dbtune.sde does not contain LOGFILE_DEFAULTS config parameter 'SESSION_STORAGE'.
WARNING: File dbtune.sde does not contain LOGFILE_DEFAULTS config parameter 'SESSION_INDEX'.
WARNING: File dbtune.sde does not contain NETWORK_DEFAULTS config parameter 'B_STORAGE'.
WARNING: File dbtune.sde does not contain NETWORK_DEFAULTS config parameter 'F_STORAGE'.
WARNING: File dbtune.sde does not contain NETWORK_DEFAULTS config parameter 'S_STORAGE'.
WARNING: File dbtune.sde does not contain NETWORK_DEFAULTS config parameter 'A_STORAGE'.
WARNING: File dbtune.sde does not contain NETWORK_DEFAULTS config parameter 'D_STORAGE'.
WARNING: File dbtune.sde does not contain NETWORK_DEFAULTS::NETWORK config parameter 'B_STORAGE'.
WARNING: File dbtune.sde does not contain NETWORK_DEFAULTS::NETWORK config parameter 'A_STORAGE'.
WARNING: File dbtune.sde does not contain NETWORK_DEFAULTS::NETWORK config parameter 'D_STORAGE'.
WARNING: File dbtune.sde does not contain NETWORK_DEFAULTS::DESC config parameter 'B_STORAGE'.
     Inserting the default values.<
18 Ответы
ответил 01 Июль, 08 от PITKS1 (20,860 баллов)
Какие записи в других лог файлах ???
SQL Server какой ?? 2005 ??? Или 2008 ??
Опиши все шаги установки полностью
ответил 01 Июль, 08 от 2bars (440 баллов)
дело в том что я раньше не имел дело ни с ГИС ни с Майкрософт SQL, мне сложно ориентироваться...
какие логи именно вам нужны?
мои действия...
я поставил MS SQL 2005, настроек никаких не делал... ткните носом, если таковые нужны... сервер запустился и работает...
поставил ArcGIS DESKTOP...  настроил менеджер лицензий, хотя... он сам настроился ;)
пытаюсь поставить ArcSDE...
пользователь sde дал все привилегии, ничего не помогает... :(
В 2005 SQL есть проблема если пароль не сложный. Юзера sde он создаст, но потом ничего с ним сделать нельзя будет.
Решение - снести SDE базу, снести SQL sde юзера, создать этого юзера руками, указав нужный пароль и указав, что не надо енфорсить правила паролей.
После этого запустить пост инсталл и все должно получиться.
ответил 01 Июль, 08 от Worker (22,480 баллов)
Да, все правильно. В 2005 SQL Server надо создать пользователя sde, но задать для него пароль более сложный, чем просто "sde". Создавайте все в схеме sde, а не dbo. Помните также о том, что на закладке security надо поставить аутентификацию средствами Windows и SQL, это обсуждалось на форуме и Data+ и ESRI, постарайтесь поискать.
ответил 02 Июль, 08 от 2bars (440 баллов)
я ему уже все права выдал какие тока можно... но он по прежнему пишет теже ошибки что и в прошлый раз :( прикладываю аттач с проделаными действиями
./index.php?qa=blob&qa_blobid=6899639617607892641
P.S. на форуме http://forums.esri.com ничего не нашел :(
что же мне так не везет...
ответил 02 Июль, 08 от Worker (22,480 баллов)
Посмотрите тут, может поможет чем.
http://forums.esri.com/Thread.asp?c=2&f=1719&t=239314
http://forums.esri.com/Thread.asp?c=2&f=59&t=70800
Можете также ввести в строке поиска на support.esri.com "Windows and SQL Server authentification". И посмотрите базу знаний техн.статьи по ArcSDE, там многое обсуждалось.
ответил 02 Июль, 08 от PITKS1 (20,860 баллов)
Базу SDE сносил перед тем как постинсталл запускать по новой ?? Или на старую базу направил ???
ответил 05 Июль, 08 от 2bars (440 баллов)
задал этот оврпос на офф форуме вот ответ
Subject Re: i have problem. ARCSDE 9.0 + MS SQL 2005 - error
Author Vince Angelo
Date Jul 02, 2008
Message You cannot use ArcSDE 9.0 with SQL-Server 2005. Support for
that database was only added at 9.1 SP1.
звучит как приговор...
Правдо ли что не поддерживает?
PITKS, да базу сносил...
Вот и проблемка...
ответил 05 Июль, 08 от PITKS1 (20,860 баллов)
Ну блин, даете. А написать, что пробуешь 9.0 ставить, а не 9.2 (в 9.1 хоть SP3 не было) - религия не позволяет??? Естественно 2005-й сервер не поддерживается в 9.0 И работать не будет.
