Ну раз такое щасте привалило, модифицируй:
'field_DMS2DD.cal
'Author: Ianko Tchoukanski
http://www.ian-ko.com
Dim sField
Dim sDMS As String, sS As String, sSuf As String
Dim sList
Dim i As Integer, j As Integer
Dim iDec As Integer, iNum As Integer
Dim dD As Double, dM As Double, dS As Double, dDD As Double
Dim bReplace As Boolean
'Change the source field name below
sField = [Long]
sDMS = sField
If Len(Trim(sDMS)) = 0 Then
dDD = 0
Else
iDec = 0
iNum = 0
For i = 1 To Len(sDMS)
sS = Mid(sDMS, i, 1)
If Not IsNumeric(sS) Then
If sS = "." Then
If Not iDec = 0 Then
bReplace = True
Else
bReplace = False
End If
iDec = iDec + 1
ElseIf UCase(sS) = "S" Or UCase(sS) = "N" Or UCase(sS) = "W" Or UCase(sS) = "E" Then
sSuf = UCase(sS)
bReplace = True
Else
bReplace = True
End If
If bReplace Then
If iNum > 0 Then
Mid(sDMS, i, 1) = ","
Else
Mid(sDMS, i, 1) = " "
End If
End If
Else
iNum = iNum + 1
End If
Next i
sList = Split(sDMS, ",")
Dim iLen As Integer
If UBound(sList) = 0 Then
sDMS = sList(0)
iLen = Len(sDMS)
If iLen >= 4 Then
dS = CDbl(Mid(sDMS, iLen - 1, 2))
dM = CDbl(Mid(sDMS, iLen - 3, 2))
sDMS = Left(sDMS, (iLen - 4))
If (Len(sDMS) > 2) Then
dD = CDbl(Right(sDMS, 3))
ElseIf (Len(sDMS) = 0) Then
dD = 0#
Else
dD = CDbl(sDMS)
End If
Else
dDD = 0
End If
dDD = dD + dM / 60# + dS / 3600#
Else
j = 0
dD = 0#
dM = 0#
dS = 0#
For i = 0 To UBound(sList)
If IsNumeric(sList(i)) Then
If j = 0 Then
dD = CDbl(sList(i))
j = j + 1
ElseIf j = 1 Then
dM = CDbl(sList(i))
j = j + 1
ElseIf j = 2 Then
dS = CDbl(sList(i))
j = j + 1
End If
End If
Next i
End If
If dDD < -180# Or dDD > 180# Then
dDD = 0#
End If
If sSuf = "S" Or sSuf = "W" Then
dDD = dDD * -1#
End If
End If
