напр. по событию MapControl1.OnMouseDown
а далее ищете точку в ближайших окрестностях из точечного слоя.
Set pActiveView = MapControl1.ActiveView
Set pmap = MapControl1.Map
Set pEnvelope = pActiveView.Extent
searchtol = (pEnvelope.XMax - pEnvelope.XMin) / 200 ' размер окрестностей, в которых ищем точку
Set pPoint = pActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(X, Y)
Set pFeature = FindFeature(searchtol, pPoint)
Public Function FindFeature(searchtol As Double, pPoint As esriGeometry.Ipoint) As Feature
' функция поиска точки по клику мышкой на карте
Dim pEnvelope As IEnvelope
Dim pSpatialFilter As ISpatialFilter
Dim pFeatureClass As IFeatureClass
Dim pFeatureCursor As IFeatureCursor
Dim pFeature As IFeature
Dim ShapeFieldName As String
Dim pmap As IMap
Set pmap = MainForm.MapControl1.Map
Set pEnvelope = pPoint.Envelope
pEnvelope.Expand searchtol, searchtol, False
'Create a new spatial filter and use the new envelope as the geometry
Set pSpatialFilter = New SpatialFilter
Set pSpatialFilter.Geometry = pEnvelope
pSpatialFilter.SpatialRel = esriSpatialRelIntersects
Set pWorkspaceFactory = New ShapefileWorkspaceFactory
Set pFeatureWorkspace = pWorkspaceFactory.OpenFromFile(Path_ServPoint, 0)
Set pFeatureClass = pFeatureWorkspace.OpenFeatureClass(Theme1)
ShapeFieldName = pFeatureClass.ShapeFieldName
Set pSpatialFilter.OutputSpatialReference(ShapeFieldName) = pmap.SpatialReference
pSpatialFilter.GeometryField = pFeatureClass.ShapeFieldName
Set pFeatureCursor = pFeatureClass.Search(pSpatialFilter, False) 'Do the search
<P =Msonormal style="MAR
