ArcSDE 9.2 for SQL Server Build 1081 Sun Sep 17 16:01:22 2006
IDBInitialize::Initialize Failed
init_DB DB_instance_open_as_dba: -93
DBMS error code: 18456
(null): (null)
encoding = UTF8
Fri Apr 27 18:51:39 2007 - ****** Spatial Database I/O Manager ******
Fri Apr 27 18:51:39 2007 - SDE System Startup Initiated . . .
Fri Apr 27 18:51:39 2007 - Validated System Paths.
Fri Apr 27 18:51:39 2007 - SDE IOMGR going into background . . .
Fri Apr 27 18:53:22 2007 - ****** Spatial Database I/O Manager ******
Fri Apr 27 18:53:22 2007 - SDE System Startup Initiated . . .
Fri Apr 27 18:53:22 2007 - Validated System Paths.
Fri Apr 27 18:53:22 2007 - SDE IOMGR going into background . .
27.04.2007 18:53:22 esri1_sde Information None 108 N/A GISBASE The description for Event ID ( 108 ) in Source ( esri1_sde ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: esri1_sde.
27.04.2007 18:53:22 esri1_sde Error None 110 N/A GISBASE The description for Event ID ( 110 ) in Source ( esri1_sde ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: esri1_sde; Connection to RDBMS failed.
27.04.2007 18:51:40 esri1_sde Information None 108 N/A GISBASE The description for Event ID ( 108 ) in Source ( esri1_sde ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: esri1_sde.
27.04.2007 18:51:40 esri1_sde Error None 110 N/A GISBASE The description for Event ID ( 110 ) in Source ( esri1_sde ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: esri1_sde; Connection to RDBMS failed.
27.04.2007 18:50:37 esri1_sde Information None 100 N/A GISBASE The description for Event ID ( 100 ) in Source ( esri1_sde ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: esri1_sde.
27.04.2007 17:45:30 Application Error Error (100) 1000 N/A GISBASE Faulting application gsrvr.exe, version 9.2.0.1081, faulting module gsrvr.exe, version 9.2.0.1081, fault address 0x0002aac2.
27.04.2007 17:16:55 MsiInstaller Information None 11707 GISBASE\Administrator GISBASE Product: ArcGIS ArcSDE for Microsoft SQL Server -- Installation operation completed successfully.
27.04.2007 16:41:15 MSSQLSERVER Information (2) 17055 GISBASE\Administrator GISBASE "8128 :
