Как вариант - заглянуть в Help и прочесть там следующее:
Q.: I used the geoprocessing wizard in version 8.x. Is there anything similar I can use?
A.: Yes. Although the ArcGIS 8.x version of the geoprocessing wizard was removed at ArcGIS 9.x, there is a new Introduction to geoprocessing panel you can add to an application that has a similar purpose as the wizard—access to commonly used tools.
To add this panel follow these steps:
In the application, click the Tools menu and click Customize.
In the Customize dialog box, click the Commands tab.
In the Categories pane, click ArcToolbox.
In the Commands pane click 'Geoprocessing...'.
Drag Geoprocessing from the Customize dialog box and drop it onto the Window menu.
Close the Customize dialog box.
The Introduction panel can now be opened by going to the Window menu and choosing Geoprocessing. From this panel, you can read information about the most popular tools, view graphical representations of each, and access their dialog boxes by clicking the Open tool.
