Вот пример bp хелпа с использованием файла *.txt
Samples
Create a layer based on XY data
Language
C#
VB.NET
VBA
Show All
Description:
This sample uses a delimited textfile table to create an XY Event layer which is then added to ArcMap. The points displayed by this layer are generated dynamically when the layer is drawn. The same approach may be take to create XY Event layers from any type of standalone table. Products:
ArcView: VBA, C#, VB.NET
Platforms: Windows
Minimum ArcGIS Release: 9.0
How to use:
Paste the code into your code file.
Create a new text file named XYSample.txt, then add the data below to the new textfile. If you name the file something else, you will need to adjust the sample code.
x,y,place
419289.2644,3744635.9201,Anaheim CA
392626.0961,3739354.4688,Long Beach CA
444090.0630,3768354.3989,Ontario CA
543630.3519,3737391.7820,Palm Springs CA
395037.5403,3780560.0343,Pasadena CA
484233.0769,3768589.0100,Redlands CA
463278.9584,3755622.1016,Riverside CA
473051.8917,3777689.9331,San Bernadino CA
362120.1377,3764646.9229,Santa Monica CA
373495.0135,3772750.7525,W Hollwood CA
Add the XYSample.txt file to ArcMap as a table.
Run the sample.
[VBA]
Private Sub AddXYEventLayer()
On Error GoTo EH
Dim pDoc As IMxDocument
Dim pMap As IMap
Set pDoc = ThisDocument
Set pMap = pDoc.FocusMap
' Get the table named XYSample.txt
Dim pStTabCol As IStandaloneTableCollection
Dim pStandaloneTable As IStandaloneTable
Dim intCount As Integer
Dim pTable As ITable
Set pStTabCol = pMap
For intCount = 0 To pStTabCol.StandaloneTableCount - 1
Set pStandaloneTable = pStTabCol.StandaloneTable(intCount)
If pStandaloneTable.Name = "XYSample.txt" Then
Set pTable = pStandaloneTable.Table
Exit For
End If
Next
If pTable Is Nothing Then
MsgBox "The table was not found"
Exit Sub
End If
' Get the table name object
Dim pDataSet As IDataset
Dim pTableName As IName
Set pDataSet = pTable
Set pTableName = pDataSet.FullName
' Specify the X and Y fields
Dim pXYEvent2FieldsProperties As IXYEvent2FieldsProperties
Set pXYEvent2FieldsProperties = New XYEvent2FieldsProperties
With pXYEvent2FieldsProperties
.XFieldName = "x"
.YFieldName = "y"
.ZFieldName = ""
End With
' Specify the projection
Dim pSpatialReferenceFactory As ISpatialReferenceFactory
Dim pProjectedCoordinateSystem As IProjectedCoordinateSystem
Set pSpatialReferenceFactory = New SpatialReferenceEnvironment
Set pProjectedCoordinateSystem = pSpatialReferenceFactory.CreateProjectedCoordinateSystem(esriSRProjCS_NAD1983UTM_11N)
' Create the XY name object and set it's properties
Dim pXYEventSourceName As IXYEventSourceName
Dim pXYName As IName
Dim pXYEventSource As IXYEventSource
Set pXYEventSourceName = New XYEventSourceName
With pXYEventSourceName
Set .EventProperties = pXYEvent2FieldsProperties
Set .SpatialReference = pProjectedCoordinateSystem
Set .EventTableName = pTableName
End With
Set pXYName = pXYEventSourceName
Set pXYEventSource = pXYName.Open
' Create a new Map Layer
Dim pFlayer As IFeatureLayer
Set pFlayer = New FeatureLayer
Set pFlayer.FeatureClass = pXYEventSource
pFlayer.Name = "Sample XY Event layer"
'Add the layer extension (this is done so that when you edit
'the layer's Source properties and click the Set Data Source
'button, the Add XY Events Dialog appears)
Dim pLayerExt As ILayerExtensions
Dim pRESPageExt As New XYDataSourcePageExtension
Set pLayerExt = pFlayer
pLayerExt.AddExtension pRESPageExt
pMap.AddLayer pFlayer
Exit Sub
EH:
MsgBox Err.Number & " " & Err.Description
End Sub
[C#]
public CreateXYLayer()
try
IMxDocument pMxDoc;
IMap pMap;
pMxDoc = (IMxDocument) m_app.Document;
pMap = pMxDoc.FocusMap;
// Get the table named XYSample.txt
IStandaloneTableCollection pStTabCol;
IStandaloneTable pStandaloneTable;
ITable pTable = null;
pStTabCol = (IStandaloneTableCollection) pMap;
for (int intCount = 0; intCount < pStTabCol.StandaloneTableCount; intCount++)
pStandaloneTable = (IStandaloneTable) pStTabCol.get_StandaloneTable(intCount);
if (pStandaloneTable.Name == "XYSample.txt")
pTable = pStandaloneTable.Table;
break;
if (pTable == null)
MessageBox.Show("The table was not found");
return;
// Get the table name object
IDataset pDataSet;
IName pTableName;
pDataSet = (IDataset) pTable;
pTableName = pDataSet.FullName;
// Specify the X and Y fields
IXYEvent2FieldsProperties pXYEvent2FieldsProperties;
pXYEvent2FieldsProperties = new XYEvent2FieldsPropertiesClass();
pXYEvent2FieldsProperties.XFieldName = "x";
pXYEvent2FieldsProperties.YFieldName = "y";
pXYEvent2FieldsProperties.ZFieldName = "";
// Specify the projection
ISpatialReferenceFactory pSpatialReferenceFactory;
pSpatialReferenceFactory = new SpatialReferenceEnvironmentClass();
IProjectedCoordinateSystem pProjectedCoordinateSystem;
pProjectedCoordinateSystem = pSpatialReferenceFactory.CreateProjectedCoordinateSystem(26911);
// esriSRProjCS_NAD1983UTM_11N
// Create the XY name object and set it's properties
IXYEventSourceNam
