Help! Люди, кто понимает ArcGis подскажите пожалуйста, такому чайнику как я как быть.
Дано задание Fading Animation. А что это, куда писать, как связать с программой не знаю.
Единственное, что нашла по теме это вот -
Description:This example demonstrates how to read and modify the transparency of a layer. The fading out of a layer in the current scene is animated by adjusting its transparency setting. Starting with the current transparency value, the symbols in the layer are recorded with increasing values towards 100, which represents full transparency.
The layer itself is then updated with the resulting transparency value so that it is consistent with the Layer Properties | Display tab value.
How to use:
- Paste the code into VBA.
- Add a drawable layer into ArcScene.
- Run the macro.
Public Sub FadingAnimation()
' get first layer
Dim g_pDoc As ISxDocument
Set g_pDoc = ThisDocument
Dim pScene As IScene
Set pScene = g_pDoc.Scene
Dim layerCount As Integer
layerCount = pScene.layerCount
Dim pLayer As ILayer
Set pLayer = pScene.Layer(0)
If (pLayer Is Nothing) Then
Exit Sub
End If
' get extension with 3D properties
Dim pLayerExts As ILayerExtensions
Set pLayerExts = pLayer
Dim i As Long
For i = 0 To pLayerExts.ExtensionCount - 1
Dim p3DProps As I3DProperties
Set p3DProps = pLayerExts.Extension(i)
If (Not p3DProps Is Nothing) Then
Exit For
End If
Next i
Dim bLighting As Boolean
bLighting = p3DProps.Illuminate
Dim bExtruded As Boolean
If (p3DProps.ExtrusionType < > esriExtrusionNone) Then
bExtruded = True
Else
bExtruded = False
End If
' get layer's symbols in scene graph
Dim pSG As ISceneGraph
Set pSG = g_pDoc.Scene.SceneGraph
Dim pSymArray As IArray
Dim pDisplayListIDs As ILongArray
pSG.GetOwnerSymbols pLayer, pSymArray, pDisplayListIDs
' read (and activate) layer's transparency
Dim currentTransp As Long
pSG.GetOwnerTransparency pLayer, currentTransp
If (currentTransp = 0) Then
pSG.SetOwnerTransparencyState pLayer, True
End If
' fading animation
Dim transp As Integer
For transp = currentTransp To 100 ' transparency value loop
Dim pSym As ISymbol
Dim listID As Long
Dim nSyms As Long
Dim s As Long
nSyms = pSymArray.Count
For s = 0 To nSyms - 1 ' symbol recording loop
Set pSym = pSymArray.Element(s)
listID = pDisplayListIDs.Element(s)
pSG.RecordSymbol pSym, listID, bExtruded, bLighting, transp, False
Next s
pSG.RefreshViewers
Next transp
' set the layer as completely transparent, for consistency
If TypeOf pLayer Is IDisplayFilterManager Then
Dim pDLManager As IDisplayFilterManager
Set pDLManager = pLayer
If (Not pDLManager Is Nothing) Then
Dim pDisplayFilter As ITransparencyDisplayFilter
Set pDisplayFilter = New TransparencyDisplayFilter
pDisplayFilter.Transparency = 255
pDLManager.DisplayFilter = pDisplayFilter
End If
End If
If TypeOf pLayer Is ILayerEffects Then
Dim pLayerEffects As ILayerEffects
Set pLayerEffects = pLayer
pLayerEffects.Transparency = 100
End If
End Sub
Теперь, я как понимаю надо это перевести на Си Шарп,
а что дальше? Как сделать, чтобы что-то заработало? Может
