Как правильно программно создать растр?
Во первых растр не создается?
Во вторых, ... см. ниже
В чем ошибка?
Private Sub cmdSpline_Click()
   Dim pIOP As IInterpolationOp
   Set pIOP = New RasterInterpolationOp
   Dim pGeoDS As IGeoDataset, pInputGDS As IGeoDataset
   Dim pOrigin As IPoint, nCols As Long, nRows As Long, _
      nCellX As Double, nCellY As Double
   Dim pSR As ISpatialReference, pEnv As IEnvelope
   Set pEnv = pPL.AreaOfInterest ' точешный слой
   nCellX = 12
   nCellY = 12
   nCols = pEnv.Width / nCellX
   nRows = pEnv.Height / nCellY
   Set pSR = GetLayerSourceSpatialRef(pPL)
   Set pOrigin = pEnv.LowerLeft
   Set pGeoDS = CreateRasterDS(sPLPath, "spline1", "tiff", pOrigin, _
      nCols, nRows, nCellX, nCellY, PT_DOUBLE, pSR)
   Set pGeoDS = CreateRasterSurf(sPLPath, "spline1", "tiff", pOrigin, _
      nCols, nRows, nCellX, nCellY, PT_DOUBLE, pSR, True)
   Set pInputGDS = pPL
' Во вторых, ... след. строка сообщает "Cold not get featureclass"
   Set pGeoDS = pIOP.Spline(pInputGDS, esriGeoAnalysisTensionSpline, 5, 50)
   MsgBox "finish!!!"
End Sub
Public Function CreateRasterSurf(sDir As String, sName As String, sFormat As String, _
  pOrigin As IPoint, nCol As Long, nRow As Long, cellsizeX As Double, cellsizeY As Double, _
  ePixelType As rstPixelType, pSR As ISpatialReference2, bPerm As Boolean) As IRasterDataset
  Dim rWksFac As IWorkspaceFactory
  Set rWksFac = New RasterWorkspaceFactory
  Dim wks As IWorkspace
  Set wks = rWksFac.OpenFromFile(sDir, 0)
  Dim rWks As IRasterWorkspace2
  Set rWks = wks
  Dim numbands As Long
  numbands = 1
  Dim pRDS As IRasterDataset
  Set pRDS = rWks.CreateRasterDataset(sName, sFormat, pOrigin, nCol, nRow, cellsizeX, cellsizeY, numbands, ePixelType, pSR, bPerm)
  Set CreateRasterSurf = pRDS
End Function
Public Function CreateRasterDS(ByVal sDir As String, ByVal sName As String, _
   sType As String, pOrigin As IPoint, nCols As Long, nRows As Long, _
   nCellX As Double, nCellY As Double, eRSTPixelType As rstPixelType, _
   Optional pSR As ISpatialReference, Optional nNumBands = 1, _
   Optional bIsPermanent As Boolean = True) As IRasterDataset
  On Error GoTo CreateRasterDS_ERR
  ' Create RasterWorkspace
  Dim pRWS As IRasterWorkspace2
  Dim pWSF As IWorkspaceFactory
  Set pWSF = New RasterWorkspaceFactory
  Dim sParentDir As String
  Dim sSubDir As String
  If Right(sDir, 1) = "\" Then sDir = Mid(sDir, 1, Len(sDir) - 1)
  sParentDir = priv_FileDir(sDir)
  sSubDir = priv_FileName(sDir)
  Dim pPropSet As IPropertySet
  Dim pWSName As IWorkspaceName
  Dim pName As IName
  If Right(sParentDir, 1) <> "\" Then sParentDir = sParentDir & "\"
  Set pName = pWSF.Create(sParentDir, sSubDir, pPropSet, 0)
  Set pRWS = pName.Open()
  Dim pSRef As ISpatialReference
  If Not pSR Is Nothing Then
    Set pSRef = pSR
  Else
    Set pSRef = New UnknownCoordinateSystem
  End If
  Dim pDelRDS As IDataset
  Set pDelRDS = pRWS.OpenRasterDataset(sName)
  If Not pDelRDS Is Nothing Then pDelRDS.Delete
  Set pRDS = pRWS.CreateRasterDataset(sName, sType, pOrigin, nCols, nRows, nCellX, nCellY, nNumBands, eRSTPixelType, pSRef, bIsPermanent)
  Set CreateRasterDS = pRDS
  Exit Function
CreateRasterDS_ERR:
  Debug.Print Err.Description
  Resume Next
End Function
