Читать документацию прежде всего.
Файлы с логами о причинах неудачного старта лежат в ArcSDE\sqlexe\etc\
Выглядеть должны так:
sde_имя_сервиса.log:
ArcSDE 9.1 SQL Server Build 2101 Thu Mar 3 18:55:48 PST 2005
Connected to instance . . .
WARNING: SDETMP: Setting temp path to c:\temp
DBMS Connection established...
RDBMS: "SQL Server"
Instance Name: "ArcGISDemo_sde"
IOMGR Process ID (PID): 904
giomgr_имя_сервиса.log:
Wed Sep 07 19:11:18 2005 - ****** Spatial Database I/O Manager ******
Wed Sep 07 19:11:18 2005 - SDE System Startup Initiated . . .
Wed Sep 07 19:11:18 2005 - Validated System Paths.
Wed Sep 07 19:11:18 2005 - SDE IOMGR going into background . . .
Wed Sep 07 19:11:18 2005 - ANSI Codepage set . . .
Wed Sep 07 19:11:18 2005 - System Parameter table 'SERVER_CONFIG' Read.
Wed Sep 07 19:11:18 2005 - Initialized Shared Memory Segment.
Wed Sep 07 19:11:18 2005 - Validated License.
Wed Sep 07 19:11:18 2005 - IOMGR Process ID (PID): 904
Wed Sep 07 19:11:18 2005 - Initialized Client Tables.
Wed Sep 07 19:11:18 2005 - Server Validated.
Wed Sep 07 19:11:18 2005 - Found TCP Service.
Wed Sep 07 19:11:18 2005 - Waiting for Client Requests . . .
Wed Sep 07 19:14:37 2005 - SDE Server Pid 2004 Registered, User: CAGIS.
Wed Sep 07 19:14:39 2005 - SDE Server 2004 exit'd with status 0
Wed Sep 07 19:14:39 2005 - SDE Server Pid 2004 Stopped, User: CAGIS.
Wed Sep 07 19:14:54 2005 - SDE Server Pid 3960 Registered, User: CAGIS.
Wed Sep 07 19:15:06 2005 - SDE Server 3960 exit'd with status 0
Wed Sep 07 19:15:06 2005 - SDE Server Pid 3960 Stopped, User: CAGIS.
Если sde что-то не понравилось то в одном из этих файлов должно быть описание ошибки.
