Попробуйте через добавление точки
Inserts copies of the input points as vertices into a Path, Ring, Polyline, or Polygon; or references to the input points into a Multipoint, TriangleFan, or TriangleStrip. This method is intended for internal use only.
Syntax
object.InsertPoints (Index, Count, newPoints )
The InsertPoints method syntax has the following object qualifier and arguments:
| Part |
Description |
| object |
An object expression that evaluates to an object in the Applies To list. |
| Index |
Required. A Long that represents the Index. |
| Count |
Required. A Long that represents the Count. |
| newPoints |
Required. An IPoint object. |
Product Availability
Available with ArcGIS Engine, ArcGIS Desktop, and ArcGIS Server.
Description
Inserts a specified number (Count) of Points into the PointCollection at the given index from an array of Points. The first Count points from the array are inserted.
< id=hhpopup =application/x-ole height=0 width=0 id=clsid:adb880a6-d8ff-11cf-9377-00aa003b7a11>< NAME="Width" VALUE="26">< NAME="Height" VALUE="26">< NAME="Command" VALUE="љ"></>
