Требуется слить любое количество шейпов в один. Попробовал переделать пример Merge, да что-то не работает последняя самая главная строка.
Может кто поможет? И вообще, ход-то мыслей правильный???
Sub MergeLayers()
  Dim pGxDialogLayer As IGxDialog
  Dim pGxObjectLayer As IGxObject
  Dim pEnumGxObjectLayer As IEnumGxObject
  Dim pGxObjectFilterLayer As IGxObjectFilter
  Dim anythingSelectedLayer As Boolean
  Set pGxObjectFilterLayer = New GxFilterFeatureClasses
  Set pGxDialogLayer = New GxDialog
  pGxDialogLayer.Title = "Layers:"
  pGxDialogLayer.AllowMultiSelect = True
  Set pGxDialogLayer.ObjectFilter = pGxObjectFilterLayer
  anythingSelectedLayer = pGxDialogLayer.DoModalOpen(Application.hWnd, pEnumGxObjectLayer)
pEnumGxObjectLayer.Reset
Dim pTable1 As ITable
Dim pTable2 As ITable
Dim pLayer As ILayer
Dim pFeatLayer As IFeatureLayer
Set pGxObjectLayer = pEnumGxObjectLayer.Next
Set pTable1 = GetTable(pGxObjectLayer)
Set pTable2 = GetTable(pGxObjectLayer)
    ' Error checking
    If pTable1 Is Nothing Then
        MsgBox "Table QI failed"
        Exit Sub
    End If
    If pTable2 Is Nothing Then
        Exit Sub
    End If
    ' Define the output feature class name and shape type
    Dim pFeatClassName As IFeatureClassName
    Set pFeatClassName = New FeatureClassName
    With pFeatClassName
        .FeatureType = esriFTSimple
        .ShapeFieldName = "Shape"
        .ShapeType = esriGeometryPolygon  'pFirstFeatClass.ShapeType
? How to get ShapeType from pTable1
    End With
    ' Set the output location and feature class name
    Dim pNewWSName As IWorkspaceName
    Set pNewWSName = New WorkspaceName
    With pNewWSName
        .WorkspaceFactoryProgID = "esriCore.ShapefileWorkspaceFactory.1"
        .PathName = "Z:\temp"
    End With
    Dim pDatasetName As IDatasetName
    Set pDatasetName = pFeatClassName
    pDatasetName.Name = "Merge_result"
    Set pDatasetName.WorkspaceName = pNewWSName
    ' Build the input set/array - these are the layers to be merged
    Dim inputArray As IArray
    Set inputArray = New esriCore.Array
    inputArray.Add pTable1
    inputArray.Add pTable2
    ' Perform the merge
    Dim pBGP As IBasicGeoprocessor
    Set pBGP = New BasicGeoprocessor
    Dim pOutputFeatClass As IFeatureClass
    Set pOutputFeatClass = pBGP.Merge(inputArray, pTable1, pFeatClassName)
End Sub
Function GetTable(pGxObject As IGxObject) As ITable
  'Use name objects because they are faster than opening objects
  'Coverage featureclasses will return null
  On Error GoTo err:
  Dim pDSType As esriDatasetType
  'Check for QI
  Dim pName As IName
  Dim pArcInfoTable As IArcInfoTable
  Set pName = pGxObject.InternalObjectName
  If TypeOf pName Is IDatasetName Then
    Set pDatasetName = pName
    pDSType = pDatasetName.Type
    If pDSType = esriDTTable Or pDSType = esriDTFeatureClass Then
      Dim pTable As ITable
      Set GetTable = pName.Open
      Exit Function
    End If
  End If
  Exit Function
err:
  If err.Number = 13 Then
    Resume Next
  End If
End Function
