Geoselect
спросил 15 Апр, 04 от valery (7,040 баллов) в категории Программные продукты Esri
Выложил новый модуль на ArcScripts - наконец-то доделали CopyApr для 8.3. Английский и русский (опционно).
http://arcscripts.esri.com/details.asp?dbid=13430
Если Модератор не возражает, в этой теме хотелось бы видеть отзывы, пожелания, ответы. Как показал опыт CopyApr, пожелания и вопросы достаточно однородны, я мог бы просто отсылать к форуму.
38 Ответы
ответил 05 Окт, 04 от valery (7,040 баллов)
TypeConvert 1.2.0.45.
http://arcscripts.esri.com/details.asp?dbid=13443
- New 'From graphics' command allows you to convert graphics elements of the active map into features. New created features are stored in corresponding feature classes, according to their geometry types. Names of new classes consists of a name, set by the user and a suffix, indicating geometry type (e.g. "classname_polyline").  Text associated with the graphics is stored into 'Text' field of the target feature class.
- 'TypeConvert' extention allows you to convert one type feature class
to another type feature class(Polygon <-> Polyline <-> Points).
Also, you can convert feature class into convex hull or envelope. In this case new polygon
feature class containing only one feature (convex hull or envelope) will be created.
- 'To Centroid' command allows you to create a new point feature class with all attributes from the center points (centroids) of the features in the current layer. A centroid of a feature is the spatial location of its envelope center.
- 'Convert to *.bln' command allows you to export feature class with 2-dimentional geometry (polyline, polygon)
to GoldenSoftware blanking file (*.bln) for using this file in GS Surfer.
- 'Stratification' command allows you to stratify current layer, classified by categories or quantities, to set of layers according the current legend. The layer must has symbology, based on single field. Names, aliases of the new feature classes are based on a attribute name, value of a class and a label of a class. All created feature classes keep attributes of source feature class. Styles of classes and categories are kept in new layers.
'TypeConvert' works with current selected layer. If more than one layer is selected, it works with the first selected layer.
'TypeConvert' works with multipart objects and MZ geometries.
Notes:
1. You can project new feature class to data frame coordinate system.
2. You can convert selected objects (features) only.
3. You can convert all objects (features) in view extent.
4. You can convert feature class into the same feature class.
5. If a point feature class is converted, a new two special fields("gsGroup","gsOrder")
will be created.'gsGroup' field contains a group number. 'gsOrder' field contains an
order number in group. It's very important for polyline feature class creatation.
You should specify group number and object number in group for each object(feature) in point feature class.
Extention install and registry:
1. Launch _Registry.bat to registry TypeConvert.dll
2. In ArcMap click Tools>Extentions and check TypeConvert.
3. Add data or open project.
4. Select(!) layer you want to convert.
5. To convert selected layer select command in 'Convert' group menu.
ответил 06 Окт, 04 от geologic (39,860 баллов)
Валерий, а учитывает ли GeoSelect выборку, которая сделана в темах?
ответил 07 Окт, 04 от valery (7,040 баллов)
Пока нет =(
Проблема в растрах, CAD темах и тп., для которых Clip (Crop) может стать совсем неформальной операцией.
TypeConvert v1.3.0.16
Новая команда - 'Remove duplicates'. Создает на основе исходного два новых слоя - "вычищенный" от дублей и с исключенными дубликатами. Сравнение производиться только по координатам без учета разницы в атрибутах.
ответил 07 Окт, 04 от geologic (39,860 баллов)
Жаль, что GeoSelect не "выбирает". Было бы логично :)
А "Remove Duplicates" интересно... Только если за топологию браться, вам понятие Tolerance придется вводить. Гляньте, как EditTools устроен - очень удобный инструмент.
GeoSelect выбирает слои из базы, а не объекты из слоя. Пока что.Smile
C толерантностью - думаю повременить - тут хитрость в примитивном интерфейсе для 8 - не хочу уходить от стандартных окон. В 9 Geoprocessing упростит жизнь, да и объектная модель там намного удобней. Вопрос как раз в том, чтобы убрать дубликаты, получившиеся в результате предыдущих операций преобразования.
EditTools - это откуда инструмент? Не нашел.
ответил 08 Окт, 04 от Stvan (7,620 баллов)
Что-то у меня TypeConvert линию в точки не хочет преобразовывать.
В девятке правда, в восьмерке не пробовал.
ответил 08 Окт, 04 от valery (7,040 баллов)
Под 9 пока не все работает. Чуть попозже будет.
Ясно
ответил 08 Окт, 04 от geologic (39,860 баллов)
