Код для объединения 2D тем
theview       = av.getactivedoc
theGraphics   = theview.GetGraphics
theProjection = theView.GetProjection
if ( (theView.GetActiveThemes.Count=0) or (theView.GetActiveThemes.Get(0).Is(ITheme)) ) then
 msgbox.error("An Active Feature Theme is Required","Exiting")
 return(nil)
end
themelist=theView.getthemes
if (TheView.getactiveThemes.count=0) then exit end
s=TheView.getactiveThemes.count
SrcTheme = theView.GetActiveThemes.Get(0)
'Ñîçäàåì íîâóþ Ftab
   outFName = av.GetProject.MakeFileName(SrcTheme.GetName, "shp")
'   outFName=("d:\gis_prj\"+(SRCTheme.GetName)).AsFileName
   outFName = FileDialog.Put(outFName, "*.shp", "Output Clipped Shapefile")
   if (outFName = Nil) then
     exit
   end
   shapeType = SRCTheme.GetFTab.FindField("Shape").GetType
   if (shapeType = #FIELD_SHAPELINE) then
     outClass = POLYLINE
   elseif (shapeType = #FIELD_SHAPEMULTIPOINT) then
     outClass = MULTIPOINT
   elseif (shapeType = #FIELD_SHAPEPOINT) then
     outClass = POINT
   elseif (shapeType = #FIELD_SHAPEPOLY) then
     outClass = POLYGON
   else
     MsgBox.Error("Invalid shape field type.", "Clip Theme")
     exit
   end
   OutputFTab = FTab.MakeNew( outFName, outClass )'Ñîçäàíèå íîâîé òàáëèöû
'Äîáàâëÿåì â íîâóþ FTab îñòàëüíûå ïîëÿ (åñëè åñòü) èç òàáëèöû òåìû
   SRCfields = List.Make
   for each f in SRCTheme.GetFTab.GetFields    'ïåðåíîñ ïîëåé èç ñòàðîé òàáëèöû â íîâóþ
     if (f.GetName = "Shape") then
       continue
     else
       fCopy = f.Clone
       SRCfields.Add(fCopy)
     end
   end
   if (SRCFields.Count > 0) then              'Äîáàâëåíèå ïîëåé, åñëè òàêèå åñòü
    OutputFTab.AddFields( SRCFields )
   end
'Äîáàâëÿåì  çàïèñè
for each r in 0..(s-1)
theFtab = theView.GetActiveThemes.Get(r).GetFTab
for each c in 0..(theFTab.GetNumRecords-1)
 aValue=theFTab.ReturnValue(theFTab.FindField("Shape"),c)
 theoutrec=outputftab.addrecord
 outputFtab.SetValue(theFTab.FindField("Shape"),theoutrec,aValue)
   for each afield in SRCfields      'Äîáàâëåíèå çíà÷åíèé âñåõ ïîëåé, êðîìå shape
     oldfield=Theftab.findfield(afield.getname)
     oldvalue=TheFtab.returnvalue(oldfield,c)
     outputftab.setValue(afield, theoutrec, oldvalue)
   end
end
end
Outputftab.seteditable(false)
if (MsgBox.YesNo("Add shapefile as theme to a view?",
  "Clip Theme", true).Not) then
  exit
end
viewList = {}
for each d in av.GetProject.GetDocs
  if (d.Is(View)) then
    viewList.Add( d )
  end
end
viewList.Add("<New View>")
addToView = MsgBox.ListAsString( viewList,"Add Theme to:", "Clip Theme" )
if (addToView <> nil) then
  if (addToView = "<New View>") then
    addToView = View.Make
    addToView.GetWin.Open
  end
  mergeTheme = FTheme.Make( OutputFTab )
  addToView.AddTheme( mergeTheme )
  ' Bring the View to the front...
  addToView.GetWin.Activate
end
av.clearstatus
Для 3D тем:
 return(nil)
end
'Ñîçäàåì íîâóþ Ftab
     exit
   end
     outClass = POLYLINEZ
     outClass = MULTIPOINTZ
     outClass = POINTZ
     outClass = MULTIPATCH
    ' elseif (shapeType = #FIELD_MULTIPATCH) then
    ' outClass = MULTIPATCH
   else
     exit
   end
